20IndigoBlue02
Dyson Analysis:
Oil Analyzers:
Oil Analyzers:
But Terry's sample showed iron at 3, which I think would be fine as well, the other sample showed 12, which is 4 times exactly more.20IndigoBlue02 said:According to Terry, the iron & aluminum are are probably from the piping of the manufacturing facility. It is insignificant to him. Though keep in mind, since we have a VOA of the batch sample (call it the baseline or control sample), you have something to compare against for UOA.
I ordered some of their CI-4+ oil to use in my TDI "soon".*bump*
Anyone at all using this in their TDI?
The 5w40. My lack of attention when ordering from Amazon netted me the CI-4+ instead of CJ-4 as I'd really wanted...Bob are you gonna go with the 15w40?
Want to do the UOA for us too? =)
They have both CJ-4 and CI-4+ versions.Any opinion on using this in my PD engine? I know to stick with 5w40 but I do not see one that is CJ-4 only CI-4. My limited understanding of oils is that PDs should use 5w40 CJ-4 oil. Correct?
I think I have found a local distributor in Canada and would like to give it a try but it does frighten me a bit in the oil finicky PDs...
Alternative oils to use?So which oil would you suggest trying out? The CI-4+ or the CJ-4 version?
Unfortunately the Canadian distributor local to me that I found has told me it is "against their policy to import it"... It will cost about $30 to ship a gallon up here from Amazon! Still looking for alternatives.
I've been using the renewable lubes biosyn 5w40 for over a year now and it has been great. I haven't bothered sending any to the lab because I know my cars run better on it. Also I've only done one oil change in the last year, I only put about 10,000 miles on the car last year, and the oil seemed to have a good texture all the way to the end. I'm only a couple thousand miles into my new oil right now. It is expensive oil, but I think it's worth it with the length of service this oil provides. I run their 10w40 and their ATF in my 2001 Jeep too.www.renewablelubes.com
There was a thread were some people were looking at it last year, but nothing much since.
the Biosyn 5w40 formula was funded by a RS4 owner who's tired of under- achieving VW specification oils...
The base of the oil is High Oleic Base Stock (HOBS), made from vegetable oils.
It supposed to meet all the latest & greatest API diesel specifications
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1173821
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=893022
I ordered some of this for my Passat 2.0t, because I'm not particularly happy with 502.00, 505.01, & 504/507 oils for my car specifically, due to fuel dilution and more annoying, oil burn (it's practically 1 quart per 2500 miles for the 504/507 oil)--- I was gonna go with Amsoil DEO, but stumpled on this on BITOG, and decided to go for it.
I do plan a UOA on my on the fresh oil also (and my used oil when I hit 5k miles on this oil).
Otty, This additive is fine when added in the proper amount. I talked to Molakul over at BITOG on this and he is suggesting 3%( (1) 8 ounce bottle is 5% by volume) by volume for a normal wearing cam which is what you have.I really want to try this stuff but can't justify the cost of the engine oil so I ordered a couple small bottles of the "biosynxtra bosster pack" an oil additive. We'll see how it goes!
http://www.renewablelube.com/TDS/89000 Bio-SynXtra Engine Booster Pak.pdf
