Rear wiper spray nozzle
jesus_man
PNW
2005 Jetta (gone), 2002 Passat (gone), 2009 JSW (VW bought), 2010 JSW
Last winter with the weather being real cold, I broke off my cap cover on the rear wiper arm. Little did I know, that I also broke off the spray nozzle. I believe this to be part # 3B9955985A
Can anyone tell me the procedure to replace this part? It appears that the "root" of the old one could still be in the hole??
Thanks!
borninabus
Arizona
-2013 JSW 6MT- -2006 Jetta DSG-
it literally just pulls out.
try threading a screw into the broken stem to remove it.
jesus_man
PNW
Thanks for confirming my initial thought. I will try that today and get a replacement on order.
Thunder Chicken
Sioux Lookout, Ontario
2012 Golf Wagon
I did the same thing a few years ago. I also bought something similar but maybe I buggered the hole it goes in trying to get true old one out….. dealer said I need a whole new wiper motor as the nozzle/tube is all one part.
I hope you have better luck than me!
jesus_man
PNW
I did have some success! Not usually my MO. I wish I would have found an even smaller screw, but this one did the trick!
Reinout
Tacoma, WA
2011 Jetta Sportwagen
Dealer won't do it but the tube is replaceable. You can get brass tube the right size from craft/model suppliers. I have fixed a couple that corroded away such that the nozzle turned with the wiper blade.
I know this is old, but do you have a write-up or link to this?
P2B
Toronto & Muskoka, Canada
Unfortunately I didn't think to take pictures, but IIRC the fix was fairly obvious and straightforward after taking the motor apart.
Reinout
Tacoma, WA
Okay, I can do that. I might start by getting my hands on a nozzle first and seeing if it'll just work that way.
For now until I can do that this is kinda fun for tailgaters
