GeWilli
So, I'm guessing that it is not a factory part? The line blew on mine just as it comes out from under the resonator heat shield. only a few blocks from home so I was able to get back no big deal.
Lines going into the brake pressure regulator from the front are in good shape, but the ones from the regulator to the flex line coming off the beam axle? not so much, as in they have a hole in the passenger side.
Aside from trying to either buy a length pre flared with the proper threaded fittings (looks like i need to get a new flex hose as well) and bending it, are there any other options? Searching hasn't turned anything up.
I'm totally overwhelmed with everything (normal life ya know) and the car is suspect enough that I can't really take it to a garage to have it done (WAG based on underbody rust state). I'm just looking for advice from all y'all folks on the most economical (time + cash) way to approach this.
edit: 1996 B4V 233k
edit: 1996 B4V 233k
