sailonner
2004 Jetta wagon BEW engine: Heard that occasionally a bad brake light circuit might indicate a problem to the computer, and it will go into limp mode? So, new driver's side rear light socket going in. The old one was falling apart at the metal circuit strips and housing, making bad connection to the upper bulb socket I can see the lower outside socket is turn signal. Lower inside is reverse. Upper dual circuit is tail/running light and brake. What the hell are the two middle sockets for? Also, wonder about using LED bulbs instead of the incandescent style. If the turn signal LED's don't have a resistor to increase the current through the circuit it can cause an error in the computer? I guess I'll order a pair of those with the built-in resistor. Any advice to avoid mistakes in this?
Diagnosing low turbo boost codes: First replaced the MAF, no joy. Checked all vacuum lines and actuators, replaced the N75 just in case, no joy. Pulled the lower turbo air tube to spin the turbo. Fine. Read about cleaning the exhaust variable vanes with oven cleaner, haven't done that yet. When I went to remove the lower EGR tube to dribble in the cleaner, it was broken completely through the ribbed section. Couldn't hear an exhaust leak there, but I suspect the exhaust side Turbo fan was getting low exhaust pressure and couldn't spin up the air side turbo. Does anybody agree?
