sleekblackbeauty
As in the title. I have a bad bearing, need to replace the wheel hub assembly. The bracket is held on by some kind of star type socket. What size is this, and what type of socket? I can't figure it out.
I must be the fortunate one; are people having difficulty with these rear mount bolts because it's the first brake job? I'm doing mine for the first time (two previously by a shop) which may have eased their removal; still tricky manuevering a breaker bar in that fender well though while on your knees.I just did mine this weekend. I am glad you got your rear calipers off. I nearly killed myself getting those rear caliper bolts off. I did not know that Hercules now lives in Puebla Mexico working for Volkswagen torqueing bolts on. Holy Cow, I can not even begin to describe the 2.5 foot long breaker bar and putting every ounce of energy that my 180 lb body could produce. I thought I was going to push the entire car off the lift before the bolt finally broke loose. Even after the initial crack it was still taking every ounce of force I had.
Reassembly in the book said 66lbs of torque plus a quarter turn, I do not know how that I can equate to 500lbs or more to break the thing loose.
Yes, I agree VW are bastards, I am not enjoying the Triple square, Torx bolts, and Allen bolts that they are putting all over gods green cars. I could not bleed my clutch this weekend, because the crap allen bolt that holds the air box on was naturally rusted and immediately stripped. I also hate the torx on the bottom engine covers, just waiting for the salt and rain to destroy those.
