Herm TDI
- Joined
- Nov 21, 2001
- TDI
- 2002 Golf GLS Malone Stage 3, P+520 nozzles, 11MM Inj pump, Sachs VR6 clutch, Stelth Race Pipe, Immo Deleat, EGR Deleat
I'm in the planning stage for the replacement of the rear axle .
Due to corrosion and fatigue the Right side "leg" of the axle has warped causing excessive tire wear.
I've compiled a list of parts let me know if you know of any thing I've missed:
Rear Axle 1J0-500-051-L
Brake line clips: (8) 5Q0 611 797 B
Rear Wheel bearings (2) 1J0-598-477-A
Rear ABS sensor (2) 1J0-927-807-B
Brake Rotor Splash Shield (L) 1J0-615-611-D
Brake Rotor Splash Shield (R) 1J0-615-612-D
