Rapidrob
Right rear axle seems to have a bearing noise? At first I thought it may be the new disk brake but it does not go away or change sound when the brakes are applied.
I also checked the parking brake. Not that either.
There is no sound if the wheel is jacked off of the ground and spun. Only with weight on it and at speeds faster than 20 MPH.
All the wheels have new sets of bearings.
I tried tightening/loosening the axle nut but that does not seem to help.
The bearing turns freely in the race ( I think it is the inner bearing) and feels just like the left side.
I do not know who made the bearings. I got them from lAutohausAZ last summer.
The sound is a low pulsing and can be heard with the windows up on my 96 TDI Wagon.
The bearing and disk does not get hot after a long drive,just this disturbing sound.
The axle shows no wear at all as I have always kept the bearing greased and adjusted.
I ordered a new set of FAG bearings to see if that helps with the sound.
Any ideas that you may have had happen and found a cure?
