graeme86
I have a 2004 R32 with single DIN Gamma and FIS cluster (immo 3)
I have single DIN connectors on my radio with GALA wire and illumination (not the Quadlock like the US R32)
I wish to install MCD and have directions in FIS.
Does anyone know the difference between the 1J0 035 191 A and 1J0 035 191 C versions?
The "C" version is listed for a later model Passat 3BG only - not a Golf.
It appears to have the same single DIN connectors on the rear.
Does this mean you may require a TMC box to translate the CAN-BUS signal to the cluster (similar to version "G" MFD when installed in Golf)
(I know I can use "A" version with no problems with 3LB)
Thank you for any information regarding this!
Graeme
Graeme
