Jetta4Dollars
- Joined
- Nov 23, 2008
- Location
- Louisville
- TDI
- 2003 TDI 1.9 Bosio 520 Sold 2011 TDI 2.0 sportswagon Buy Back VW 2013 Audi Q7 Prestige 20"
I just completed an oil cooler gasket replacement, and while I had the car apart I replaced all the injector seals because one of them was leaking out the weep hole on the side of the head. After completing the job I cranked the motor several tries without it firing. I ran the tank fuel pump with VCDS, Dont think it was needed but I did, I opened the lines at the injectors, I also removed the return lines to verify I have fuel at the injector. I have checked all my electrical connections that I disconnected. I have connected VCDS and have not faults. Any ideas on what to check next? Will Ross-Tech Hex+Can diagnose a car without it running? The car is tuned with Malone Stage II, Thanks for any assistance you can provide.
Tuesday,01,November,2022,20:44:56:44646
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 22.9.0.0 (x64)
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: WA1VMAFE6DD013279 License Plate: MINE
Mileage: 295230km-183447mi Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
55 56 5F 62 69 6C 6D 6F 72
VIN: WA1VMAFE6DD013279 Mileage: 295230km-183447miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 A HW: 4L0 907 401 E
Component: 3.0TDI FSA X21 0014
Revision: 54X21--- Serial number: CVN: 1B2B25025C3E0D04755A211300000000
Coding: 2A2A4012253600050000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM30TDI0114L2910401A 001015
ROD: EV_ECM30TDI0114L2910401A.rod
VCID: 2241CC053561979D75-8076
VINID: 9D106675159519450004308724F0D49B85
No fault code found.
Readiness: 0 0 0 1 X
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AQ HW: 0C8 927 750 AQ
Component: AL1000 AISIN 002 3399
Serial number: CVN: 0478EC02
Coding: 001378
Shop #: WSC 99999 999 83333
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 7BFFD161F24B065516-802E
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099441
Shop #: WSC 31414 790 00001
VCID: 346D3A5D5795092D97-8060
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702050506
Coding: 0000135
VCID: 254BD719EC4F60A510-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
9 Faults Found:
00191 - Passenger's Door Handle Touch Sensor (G416)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 8
Reset counter: 93
Mileage: 226524 km
Time Indication: 0
Date: 2021.03.16
Time: 07:01:40
00956 - Key 2
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 9
Reset counter: 173
Time Indication: 0
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 3
Fault Frequency: 62
Reset counter: 74
Mileage: 199342 km
Time Indication: 0
Date: 2020.06.30
Time: 09:35:27
007 - Short to Ground
Freeze Frame:
Fault Status: 00111011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 121
Mileage: 226388 km
Time Indication: 0
Date: 2021.03.14
Time: 16:57:52
00192 - Rear Left Door Handle Touch Sensor (G417)
Freeze Frame:
Fault Status: 00110111
Fault Priority: 3
Fault Frequency: 2
Reset counter: 112
Mileage: 230947 km
Time Indication: 0
Date: 2021.04.22
Time: 07:45:40
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 172
Mileage: 230706 km
Time Indication: 0
Date: 2021.04.20
Time: 11:27:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 108
Mileage: 235233 km
Time Indication: 0
Date: 2021.05.28
Time: 10:27:19
00193 - Rear Right Door Handle Touch Sensor (G418)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 206
Mileage: 246420 km
Time Indication: 0
Date: 2021.08.31
Time: 15:35:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 46
Reset counter: 245
Mileage: 246573 km
Time Indication: 0
Date: 2021.09.02
Time: 06:33:53
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000000366331
Coding: 0304A036
VCID: 254BD7192C4F60A510-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0052527638
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0052527945
Coding: 070000
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 3
Reset counter: 213
Mileage: 295236 km
Time Indication: 0
Date: 2022.10.31
Time: 16:03:40
Freeze Frame:
Voltage: 9.90 V
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0139123
VCID: 6ED9E835793963FDA1-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961306500827
Coding: 25011E
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 346D3A5D9F95092D97-8060
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH44 0230
Revision: 08H44000 Serial number: 0038QD0C2ZBO
Coding: 0014131
VCID: 2B5F21218AAB56D5C6-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME7C294974T
Subsystem 3 - Serial number: 6342QSME412B4366D
Subsystem 4 - Serial number: 6352QSME03233F7EO
Subsystem 5 - Serial number: 6362QSME3C2B1D46U
Subsystem 6 - Serial number: 63734SME232B0C50-
Subsystem 7 - Serial number: 63834SME252B146E4
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 F
Component: J0527 0830
Revision: 00H08000 Serial number: 90026130300063
Coding: 0012242
VCID: 2855DE2D9B5D7DCD2B-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 Q HW: 4L0 920 985 Q
Component: KOMBIINSTR. H35 0317
Revision: 00000000 Serial number: VJ440KC3E
Coding: 8BD664040900CF05020205
VCID: 42816C85DD21B79D15-8016
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB700037 Serial number: 3700M132220004
Coding: 00C303
VCID: 3F876571AED3DA757A-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 30060I43484120270899
1 Fault Found:
03041 - Energy Management Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 213
Mileage: 295236 km
Time Indication: 0
Date: 2022.10.31
Time: 16:14:33
Freeze Frame:
Bin. Bits: 10000
Voltage: 11.60 V
Count: 10
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000030274220
Coding: 0000006
VCID: 68D59E2D5BDDBDCDEB-803C
3 Faults Found:
00003 - Control Module
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 14
Reset counter: 255
Mileage: 201713 km
Time Indication: 0
Date: 2020.07.28
Time: 10:55:39
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 213
Mileage: 295236 km
Time Indication: 0
Date: 2022.10.31
Time: 16:03:40
Freeze Frame:
Voltage: 9.80 V
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000054981406
Coding: 011F57205E40440004
VCID: 48957EADFB1D9DCDCB-801C
1 Fault Found:
01705 - Selection Switch for Mirror-Adjust (E48)
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 247
Reset counter: 210
Mileage: 273660 km
Time Indication: 0
Date: 2022.04.25
Time: 15:21:38
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01922812600000
Coding: 3569949
VCID: 38750E6D4BFDED4DBB-806C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004000 Serial number: 00000000017022
Coding: 030000
VCID: 2953DB29405744C534-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005190065267
Coding: 0758477
VCID: 234FC901E27B9E957E-8076
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 6
Reset counter: 213
Mileage: 295236 km
Time Indication: 0
Date: 2022.10.31
Time: 16:03:18
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 9.60 V
Temperature: 18.0°C
(no units): 0.0
End-------------------------(Elapsed Time: 03:58)--------------------------
www.Ross-Tech.com
Coding: 001378
Revision: 00H02001
Coding: 0099441
Coding: 0000135
9 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 93
Mileage: 226524 km
Time Indication: 0
Date: 2021.03.16
Time: 07:01:40
00956 - Key 2
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 173
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 62
Reset counter: 74
Mileage: 199342 km
Time Indication: 0
Date: 2020.06.30
Time: 09:35:27
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 121
Mileage: 226388 km
Time Indication: 0
Date: 2021.03.14
Time: 16:57:52
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 112
Mileage: 230947 km
Time Indication: 0
Date: 2021.04.22
Time: 07:45:40
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 172
Mileage: 230706 km
Time Indication: 0
Date: 2021.04.20
Time: 11:27:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 108
Mileage: 235233 km
Time Indication: 0
Date: 2021.05.28
Time: 10:27:19
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 206
Mileage: 246420 km
Time Indication: 0
Date: 2021.08.31
Time: 15:35:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 46
Reset counter: 245
Mileage: 246573 km
Time Indication: 0
Date: 2021.09.02
Time: 06:33:53
Coding: 0304A036
Coding: 070000
Coding: 070000
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 213
Mileage: 295236 km
Time Indication: 0
Date: 2022.10.31
Time: 16:03:40
Freeze Frame:
Voltage: 9.90 V
Coding: 0139123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Coding: 25011E
Coding: 0014131
Coding: 0012242
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 213
Mileage: 295236 km
Time Indication: 0
Date: 2022.10.31
Time: 16:14:33
Freeze Frame:
Bin. Bits: 10000
Voltage: 11.60 V
Count: 10
Coding: 0000006
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 255
Mileage: 201713 km
Time Indication: 0
Date: 2020.07.28
Time: 10:55:39
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 213
Mileage: 295236 km
Time Indication: 0
Date: 2022.10.31
Time: 16:03:40
Freeze Frame:
Voltage: 9.80 V
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 210
Mileage: 273660 km
Time Indication: 0
Date: 2022.04.25
Time: 15:21:38
Coding: 3569949
Coding: 030000
Coding: 0758477
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 213
Mileage: 295236 km
Time Indication: 0
Date: 2022.10.31
Time: 16:03:18
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 9.60 V
Temperature: 18.0°C
(no units): 0.0
