MarsBar
- Joined
- Apr 28, 2008
- Location
- San Jose, CA
- TDI
- B4V#2 "Flash", 2000 Jetta GL, B4V#1 "PaTuDI" (2008-2018 RIP)
Realized just how messy and all over the place the saga of my B4V stumble/die issue is, so I'm going to put it all in just this thread. Here's the history --
2013
April: guru diagnosed limp mode, repaired blk/wh wire, relay 109 replaced, N75 replaced
May: stumbling problem begins, replaced relay 109 again just because. Problem continues, happens more often as time goes on
Aug: cleaned red battery terminal, helped for a short time
Sept: flex pipe breaks, and the stumbling issue goes away until the pipe is repaired
Nov/Dec: problem is getting worse again
2014
Jan or so: replaced red battery cable lug that was seriously eroded.
Problem goes away immediately, totally, and completely and I do the dance of joy. Until. . .
2015
Feb: replaced battery
Mar/Apr: problem begins again, slowly at first then gets worse
Dec: parked the *#^@& thing and borrowed a friends car. Matt came by, rode around with me for almost an hour with zero failure, no codes, nothing unusual showing up on VCDS. Checked N109, wires, nothing found. Pulled the check valve by the fuel tank, a little narrowed, so drilled it out on a hunch.
2016
Mar: here we go again, parked it & borrowed a friends Ranger
Apr: no problem 'cause I'm not driving it!
May: accident on freeway in Ranger (I'm ok, it's not). Resurrect the B4V, pull the sender. There were bits of "stuff" in the fuel in tank, so pumped out & filtered/strained the fuel, saw one glob of something through the pump hose. Not a spec of difference. Guru wondering about water in fuel system, rust.
So, to summarize -- at first, the car will occasionally stumble when turning left from a stop light, as soon as I put the clutch in it will die. If feather the throttle, it will stumble along for a minute or so before dying. It always fires right back up. As time progresses, it starts doing it at any time under literally any circumstance -- cruising on the highway, taking off from a stop light, turning, straight, warmed up, cold, full tank, low fuel, etc. I can't make it happen, it's pretty much random, even more frustrating.
It actually went away completely after replacing the red battery cable lug, until I had to replace the battery. There has to be a clue in there somewhere, even though I know the battery is out of the equation once the engine fires up. It also went dormant while the flex pipe was broken and started again after that repair was made.
My question about the water/rust possibility is how long would something like that take to worsen to the point of disabling the car? This has been going on for 3 years and doesn't ever get bad enough to fail completely.
Parts that have been replaced/repaired/verified as good:
Relay 109 (twice), N75, ignition, battery, black/white wire to N109, red batt cable lug, fuel filter (twice)
Gurus have been working along with us on this, and even they have gotten stumped/perplexed. I've gone through probably 100 pages of various search results over the past few days, all the folks that have had similar issues have also had no-starts, which I have never had.
Alrighty folks, what the firetruck is this?
2013
2014
2015
2016
