It may depend on your home garage opener.
1. Use the Infotainment menu to start programming the Homelink button.
2. When you start the programming - hold your garage remote in front of your TReg VW emblem (in the grill) until the four way flashers blink.
a. the infotainment dialog screen will tell you you have a few minutes to accomplish this task
note: if you are in range of your garage door - it will go up and down as you are programming the homelink.
3. Your garage opener may have a "learn" feature—might need a ladder to access it. If you run into trouble, you can call the
liftmaster phone number for help.
a. activate the learn mode on the opener
b. press the newly programmed Homelink button for the garage door to learn it.
4. if the garage door activates - success otherwise back to the drawing board.
