Hi,
auto scan :
unday,27,June,2021,07:13:28:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVWZZZAUZFP556075 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZFP556075 Mileage: 240930km-149706miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 7545
Revision: 83H22---
Coding: 111D0032032405082000
Shop #: WSC 00028 028 00204
ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AFB47EFFDDF505645-802E
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 041 P HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4507
Revision: 05853104 Serial number: TFK01409151803
Coding: 0014
Shop #: WSC 00028 028 00209
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 2541449324E10FAE58-8070
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62724000000723
Coding: 04FA62A1242509720377060741C82920462490C0608294F30062507AC202
Shop #: WSC 00028 028 00248
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_033.rod
VCID: 4581E413C4A1EFAE78-8010
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 AF HW: 5G0 907 044 AF
Component: Climatronic H03 0912
Revision: 00001K08
Coding: 02020104202100011005004000101000
Shop #: WSC 00028 028 00067
ASAM Dataset: EV_ACClimaBHBVW37X 003018
ROD: EV_ACClimaBHBVW37X_003_VW37.rod
VCID: 6BD572AB8285F9DECE-803E
Fresh Air Blower Front:
Geber für Kältemitteldruck/Kältemitteltemperatur:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86580410140583
Coding: 00001A42C24102FB4BE44000000C07081000000000000000000000000000
Shop #: WSC 00078 790 12345
ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
ROD: EV_BCMBOSCH_013.rod
VCID: 79F958E3F8D95B4E4C-802C
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140905 043 0551
Serial number: 140920203128
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y14M10D10H15M24S43
Coding: 00A8DD
Relative Air Humidity Interior Sender:
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 F HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0047
Revision: -------- Serial number: 39431427100099
Coding: 0031061051
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 428BFF0FD58FD8965D-8016
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R0BNNP4
Coding: 98CCC000000000005C0000CF004800000065
Shop #: WSC 00028 028 00057
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4189F003D089C38E44-8014
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 003 009 14
Component: SideSensor_Df 001 0887
Serial number: 3576700000080D44F01U
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 002 609 14
Component: SideSensor_Pf 001 0887
Serial number: 35867000000D2261111D
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 402 309 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502BF176A6B4B06O
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 402 409 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502B3175A90393A8
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 401 909 14
Component: FrontSensor_D 001 6149
Serial number: 3556502BD176A6B4A17R
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20140926400075
Coding: 0410
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F8DF6FBA67DB57E32-806A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 741 HW: 5G1 920 741
Component: KOMBI 204 4270
Coding: 07A511082B90000800086A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009037
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 64C719976F5BB6A68F-8030
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 02101410800859
Coding: 030100040B087300EF00024A1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0038
Serial number: 27140002390380024391
Coding: 28FFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 6711464603
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 C HW: 5Q4 959 593 B
Component: TSG FS 009 0015
Serial number: 0000119708121
Coding: 003B0320D000020000001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000006743261
Coding: 010000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 0303
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB_010.rod
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 C HW: 5Q4 959 592 B
Component: TSG BFS 009 0015
Serial number: 0000119616374
Coding: 003B0120DE00020000801000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 4487F917CF9BD6A66F-8010
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000006686744
Coding: 090000
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 069800000B000200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
VCID: 408FF507DB83CA864B-8014
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 846 A HW: 5G0 035 846 A
Component: MU-S-N-ER 041 0430
Serial number: V1F02809140617
Coding: 02730201FF00000011110001000800001F0100840100010045
ASAM Dataset: EV_MUStd4CPASE 002039
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 275D4E9B5EED1DBE6A-8072
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9PS4041SQ
Data medium:
Subsystem 2 - Part No SW: 5G0 919 866 BD HW: -----------
Component: ECE 2020/21 --- 0094
Serial number: --------------------
