S
SkyPup
Guest
Here are the data for the Brake Specific Fuel Consumption (g/Kwhr), Torque (Nm), and Horsepower (Kw) for the 98-99 North American TDI engine rated at 66Kw (90 HP)at 3,750 rpm and 210Nm (155 lbs)at 1,900 rpm. A3 TDI are similar except they put out 66Kw (90 HP)at 4,000 rpm and 205Nm (149 lbs)at 1,900 rpm.
RPM (G/Kwhr) POWER TORQUE
brake specific cons (Kw) (Nm)
1,000 210 15 150
1,500 200 30 190
2,000 190 44 210
2,500 210 54 205
3,000 225 60 190
3,500 240 65 175
4,000 250 65 160
4,500 265 35 80
What this info shows for the VW TDI is that torque is strongest from 1,500-2,500 and signs off rapidly after 3,000 rpm. Horsepower doubles from 1,000 to 1,500, and then doubles again from 1,500 to 3,000, signing off at 4,000 rapidly.
Best Fuel Specific Fuel Consumption is from 1,500 rpm to 2,500 rpm where is a big dip in consumption above idle engine at 2,500 with the low at about 2,000. For best fuel mileage, keep the engine between 1,500 and 2,500 at all times!
Hmmm, it is kinda hard to keep things inline when attempting to create columns. The data is to be read from left to right across, and then it matches the headings with RPM first, BRAKE SPECIFIC FUEL CONSUMPTION 2nd (G/Kwhr), POWER 3rd (Kw), TORQUE(Nm) 4th.
99 JETTA TDI HERR WETTERAUER TORQUEMEISTER
98 KAFER WETT SPEKTAKULARE TURBOKOMPRESSOR
97 KTM 620 ADVENTURE RALLY PARIS-DAKAR SUPER THUMPER
ICH LEBE MEIN TECHORAD JETTA TDI MIT DIREKTEINSPRITZER TURBOKOMPRESSOR
[This message has been edited by SkyPup (edited August 09, 1999).]
1,000 210 15 150
1,500 200 30 190
2,000 190 44 210
2,500 210 54 205
3,000 225 60 190
3,500 240 65 175
4,000 250 65 160
4,500 265 35 80
