TDIHelpMe
I start college in two weeks and will have to commute daily. My father gave me his 2006 Jetta TDI with about 100k on the dial. He has done all the servicing himself and is pretty fanatic about it. About two months ago while I was driving the clutch pedal went to the floor. I actually picked it up with my foot and it starting working fine again for about a month. then it went to the floor and there it stayed. My father has been extremely busy so he gave me the VW manual and said fix it. I replaced the master and slave clutch cylinders and also both lines from the reservoir to the slave. when I go to bleed the system I get a milky discharge and the pedal does not come back. I use a power bleeder and follow the manual step per step. My father came out and said I did everything the correct way and we switched out the clutch and slave cylinders again with new parts and had the same results. I'm at my wits end. The brakes work great. So any advice would be greatly appreciated. The next step maybe for a good mechanic in our area.
