Bengoshi2000
So Thursday I was driving back to work from lunch and the braking action started to get hard. I know, that's what she said...
Yesterday I could get 'er to stop, but it was clear there was zero power assist. It was like braking on my old '66 Mustang. No problems with stopping other than the gargantuan effort required. Pedal was hard and firm, no softness. <cough>
So this morning I brought out the mityvac:
Note: My hose from the vacuum pump to the booster was replaced about 18 months ago. All vac lines and connectors were replaced 10 months ago. The check valve between the pump and the booster was working properly (i.e. I could blow air into the small orifice, but couldn't suck air out of it).
With the engine off and the MV connected directly to the vacuum pump nipple, I could pump it down to 24hg. Connected directly to the booster, 4hg.
Engine running. Directly connected to vacuum pump, 27hg. Jiggling the nipple would occasionally cause a brief drop in hg, but never more than 2 or 3. Turn the engine off and it held vac for 20 minutes. Jiggled nipple and couldn't get it to affect the vacuum.
Engine running and MV connected to the small orifice coming out of the vac pump to booster check valve, 27hg (but it took 5-10 seconds to get there). Pump the brake pedal and the vac would drop to 3 or 4.
I did check the nipple on the booster and it's remarkably loose. Tried to hold it tight to see if I could get vacuum... no dice.
Seems like the booster won't hold any vacuum. Do the minds gathered here concur? Should I check anything else?
