dieseljunkie
I felt a slow loss of power assist to the steering last night. Just so happen I have a fresh can of CH-11 pwr steering fluid so I filled the empty reservoir and started up the engine and saw fluid dripping out the bottom of engine.. Closeer look revealed the lower steel line on the pwr steering rack has 3 pinhole leaks squirting out fluid. VW must use crappy lines! I have a MB older than the Passat by 12 years and have no problems with lines rusting out. I better go check my brake lines and other metal lines for rust!Is the lower line the high pressure line? Is it dealer item only?
