1dieselsteve
Hey I saw this oil for sale, has anybody ever heard of it or has experience on using this oil in their car. I've never heard of it before.
Yes, use it all the time. Very high quality German product carried by the better parts stores in my neck of the woods.Hey I saw this oil for sale, has anybody ever heard of it or has experience on using this oil in their car. I've never heard of it before.
Do you use it on both of your vw's? Which oil do you use, and oil filter. How much is it for an do it yourself oil change.Yes, use it all the time. Very high quality German product carried by the better parts stores in my neck of the woods.
I've used it on my wife's Civic, Camry, (both sold) my 2 TDI's that I have had, my Westfalia, my wife's current Passat. I'm lucky that my german fleet can all use 5w40. I also recently started using their brake fluid. I haven't purchased their oil filter as I usually use Mann or Hengst which is more common here. Oil in Canada is usually 40% more expensive than in the USA. A 4L jug of this stuff is usually around $50 taxes in. I have my own Pela pump. A Mann filter is around $8. If you plan on having your car a long time, get a Pela pump. I also use Rotella T6 5w40 which I buy at Wal Mart in the states for around $23.Do you use it on both of your vw's? Which oil do you use, and oil filter. How much is it for an do it yourself oil change.
507 only comes in 5w30Went to O'Reiley's and they have it as 5W30 but they recommended 5W40
As I understand it from reading the oil gurus in this forum, ALL 507.00 oils are 5W-30. Accept no substitutes.....507 only comes in 5w30
Man, if you are getting low TBN at a low 7,500 miles or 10,000 miles, YOUR OIL IS CRAP! You should switch immediately!I personally shortened my drain interval to 7500 miles due to the low TBN being noted on numerous oil analyses documents.
