PD130 / PD150 Intake Manifolds
Sprocket
Sprockette's hubby
MI
2014 Jeep Grand Cherokee Summit Eco Diesel, 2005 Passat Silverstone Grey, 1996 Passat Storm Grey
Does anybody have a list of engine codes for the European VW/Audi vehicles that would have PD130 or PD150 manifolds? I may have a source of getting some manifolds from Germany if I can give said person the engine codes. All I have at the moment are:
AFN
ASZ
ARL
Rub87
Belgium
Ibiza '99 90HP
afn is wrong.. BXE BKC, BLT, AWX AVF, BLT etc all use them too.. to many to sum up..
devonutopia
Devon, U.K
PD300 Skoda Fabia
The UK pd130 & pd150 all have the manifolds pointing to the left (as you look at the engine from the front) See mine for comparison. This is an ASZ manifold, although no longer "stock" :D
fenwick458
England
'12 T5 Van
AWX and AVF are longditudnally mounted and the intake manifold part numbers are 038 129 713 AJ or 038 129 713 AG pictured below.......
and ARL, ASZ, BPX are the normal style intake manifolds that go to the left, p/n 038 129 713 AF pictured below
and the others mentioned BXE, BKC, BLS & BLT are from the mk5 "105" and the AXR engine
P/N 038 129 713 BC, pictured below
note that the "BC" intake has a different stud pattern to the EGR. the other ones i mentioned above all have the same stud pattern and will accept the large bore EGR(of which theres 2 versions, one from a long engine and one from a transverse, difference is the side which the actuator is mounted on)
but if you get a "BC" intake you will have to specify this when buying your racepipe, street toys sells a BC racepipe
and then there are 2 more intake manifolds which i have recently found, i have no idea where they came from but the part numbers are 03G 129 713 B and C
03G 129 713 B has the same EGR bolt pattern as the regular pd150/pd130 intake 038 129 713 AF
03G 129 713 C has the same EGR bolt pattern as the AXR manifold 038 129 713 BC
G60ING
Alexandria, VA
Is it feasible that a BC's EGR valve could fit on a Passat PD 130 intake manifold (038-129-713-AJ or 038-129-713-AG) with only minor modification of the holes on the EGR? Maybe I could slot them or would the o-ring on seat on the intake manifold's flange?
The reason why I ask is because I want to use an EGR valve without the shutdown flap on my mk3 AHU. here is the EGR that I want to use: http://cgi.ebay.co.uk/VOLKSWAGEN-GO...arts_Vehicles_CarParts_SM&hash=item4152221e42
FlyTDI Guy
PNW
'01 Jetta GLS
Great info fenwick... I've got the ARL (038 129 713 AF) version and am having a time finding a proper EGR and upper charge hose for it. You don't have any good leads or part numbers I can pursue do you??
RomSL
Philly
Porsche Cayenne
You need EGR with this part-number 038131501AT. But you also will need new elbow hose 1J0145838AF
Farfromovin
Torque Addict
Ventura, CA
03 Golf 2dr- PD150 6m
Great pics Fenwick. I've noticed you seem to have pics of all those hard to find parts for some odd reason!
fenwick458
England
'12 T5 Van
yes, minor modding of the holes on the EGR would work no problem, one of the holes will need ovalling 1-2mm.
are you sure that EGR in the picture on the ad is what you will get? it looks to me like they have loads of different EGR's, you give them your engine code and they send you an EGR.
G60ING
Alexandria, VA
I don't think I'm going to use that ebay auction. slow-moe posted that the part number is 038-131-501-AN I think that I'll buy it through worldimpex.com when I order some other parts for my turbo conversion.
ryanp
Barnsley, South Yorkshire, UK
Arosa CR - 550hp - 9.7 @ 150mph 1/4 Mile, Citigo 4x4 CR TDi - 340hp, Caddy 2.0 CR 4x4 TDI - 300+hp, Golf Mk2 Van 1.9 TDI - was 290hp, Mk5 Ibiza 2.0 FR TDi - 270hp, BMW 135d - 360hp, BMW 330d - 335hp, BMW 335d - 380hp + a few more ........
any will work, only the AF one fits as stock with egr etc.
mlemorie
Romulus Michigan
2004 Jetta
Sorry for the exumation, but Im getting a pd150 manifold P/N 03G 129 713. It doesnt have a suffix on it, so I figured Id see if you guys could steer me towards the correct EGR/Race pipe for it. I highly doubt that my stock BEW ASV would bolt up and retain operation though correct? Just out of curiousity, do any of the different p/n manifolds have any distinct advantage over the others?
FlyTDI Guy
PNW
'01 Jetta GLS
In your case, please examine the length of the inlet and the mounting face for the ASV/EGR components. The more common of the pass. side inlet types would be the 038 129 713 AF. See post #16 above. If you're getting a race pipe for it, the length will have to be long(er) as needed. As for fitting an EGR assy, I suggest getting w/RyanP about that.
apples12
Birmingham, United Kingdom
Mk5 1.9tdi Match, BMW F10 520D
thread revival...
Am i correct in thinking an intake manifold from an AXR engine will fit directly onto a mk5 BKC engine?
part numbers from etka are different...
kamaksi
Bloomsburg Pa
Jetta (2002)
which of these would work best for 2002 Jetta Tdi with a stock intake.... i eventually plan on changing that but just one piece at a time... already have EGR delete in programming from rocket chip stage 2... i found an intake online --> VW SEAT SKODA AUDI A3 1.9 TDI PD BXE DIESEL INLET MANIFOLD BREAKING 03G129713 --> will this work for my car?
devonutopia
Devon, U.K
PD300 Skoda Fabia
I have a manifold here ending in AF (bottom left one in pic above) - Seems to be the accepted PD150 manifold.
