mnelsonx
This was the previous post on the subject. I agree that it's annoying; I have to remember to turn it off, too.That's available in the MFA, turn off the check box on ATA confirm.
Yeah, the box is checked in the MFD. Not sure why the window-roll-up feature works when I poor water on the sensor but the wipers wont move. HmmmmYou have to turn it on in the MFD if I remember correctly also...
Did a little more searching and found what I needed in the emissions category.Can anyone post pictures or give a good description on how to access ash loading?
Jared
I live in Richmond, if you are ever down this way I would have no issues!Anyone in MD, VA, DC PA, DE has NMS VCDS, that could help me to code it.
What did you want to change about ash loading?Did a little more searching and found what I needed in the emissions category.
Not really looking to change anything.....just curious is all. Wanting to compare ash loading to other vehicles. Mine seems to be on par with other DPF equipped vehiclesWhat did you want to change about ash loading?
Sent from my iPad using Tapatalk HD
You sure? I'm not quite sure, does he?I think compu_85 is in Springfield and has VCDS.![]()
anyone know how to "unlock" the kessy? i was told by my dealership that since its illegal to have remote start here it has been deactivated... i would assume it can be done via the vag-com but would have no idea how to do it.
Are you in Germany? What part of kessy is 'locked'? Do you just need to make the remote start feature work?
Someone will pop in with an answer...
Bill
Seat Belt Chime (Saudie)
17-Instruments
Adaptation
Seat Belt Warning
Version 3
Comfort Blinkers set from 2 to 5, 4 is stock
BCM
Adaptation (address 9)
comfort blinkers in the title
Auto rain sensing wipers-
09-Cent. Elect
Coding - 07
Dropdown, RLS
Long Coding Helper
Byte 0 Bit 5 uncheck Rain Sensor inactive
Byte 0 Bit 2 checked Rain closing active
Auto rain close
09-Cent. Elect
Coding - 07
Long Coding Helper
Byte 4 Bit 5 checked Comfort op via rain sensor
Byte 4 Bit 6 checked comfort op via rain sensor active
DRL menu off option
09-Cent. Elect
Coding - 07
Long Coding Helper
Byte 15 Bit 7 checked
DRL on only when switch set to Auto
09-Cent. Elect
Coding - 07
Long Coding Helper
Byte 26 Bit 3 checked
China VCDS Headlight thread change recommendations
09-Cent. Elect
Coding - 07
Long Coding Helper
Byte 15 Bit 5 checked Parking Lights OFF with Terminal S OFF and light switch at Low beam
Byte 15 Bit 6 checked DRL via separate Lights active
Byte 15 Bit 7 checked DRL Adaptation active (MFA+)
Byte 19 Bit 0-3 Headlight extension inactive
Byte 27 Bit 2 checked LED-DRL Mod for Parking/Position light & DRL
open Sunroof fob
4F-Centr. Electr. II
**These are the steps within VCDS software to add Navigation voice commands back in (Remember to have car doors closed and unlocked before you start):
1. SELECT
2. 37 NAVIGATION
3. CODING - 07
4. LONG CODING HELPER
5. Highlight BYTE 7
6. Remove check from BIT 1
7. ESC out from this screen
8. DO IT!
9. Exit out of VCDS software
After you are through, I would recommend that you re-boot the Nav unit:
Press and hold these three button at the top of the Nav unit until it reboots. Should take about 15 seconds:
< > and star button (far right of DVD slot)
I am not sure why but my RNS510 is very slow....I push a radio station and it takes two seconds to switch. It is very annoying. Is there a firmware update to improve this?And, for the record, I find the performance of the RNS510 to be acceptible, and usually not slow at all. I have experience slowness, but tha has been the rare exception rather than the norm
Lew
