My car started flashing the Glow Plug light when i was driving and i turned the car off and it went away, about 30 mins later it started flashing again this time accompanied with the MIL light and a total loss of acceleration going into limp mode. I got the codes read at the local auto zone and the said it was P00AF (Turbo Charger Boost Control A Module). I read this thread real quick (http://forums.tdiclub.com/showthread.php?t=348006) and saw there might be a fix to the problem without replacing the turbo. VW said they tried a good recirculation valve (I'm not sure if that the same thing as the Turbo actuator valve mentioned in the other thread) but they said it was no good and had oil in it, and that the turbo needs replaced for $3300. They did give me the option to also bring in another turbo i just won't have a warranty, but it could save me about $1200. My question is does anybody have any info to help me decide on a new turbo from an aftermarket vendor. I check ID Parts and found 2 options, one being a larger turbo from European TDI's (http://www.idparts.com/borg-warner-cr170-turbocharger-cbeacjaa-p-4090.html) but it mentions that there will need to be modifications done. I do not know much about what would be required but i figured if I'm going to have to replace the turbo i should go ahead and add a little performance for the price over the stock option (http://www.idparts.com/borg-warner-cr140-turbocharger-cbea-cjaa-p-2564.html). Can anyone give me info on what modifications are required or if there is a kit to make the larger turbo work, or even recommendations on other turbo setups? Thanks in advance for any help given.
