DarrenUK
Introduction
Due to the lack of a production PPO (aka SVO) vehicle I have decided to optimise an existing vehicle for PPO use. Due largely to the standard fitment of many sensors to the VW Audi Group TDi engines and its suitability to run on PPO (A Number of German companies offer single tank TDi conversions and it has a deep combustion chamber similar to that used in the Elsbett engine) this engine was identified as a prime candidate.
I obtained a 1999 1.9 Tdi Skoda (VAG 1.9 ltr AGR engine) as a suitable testbed. A number of additional sensors will be added and base data recorded for later comparison.
Research shows that a number of engine management variables can be altered. Doing so is not advisable without having a good understanding of what you are altering and what it is likely to change (a way of monitoring affects would also be of value). To get what is necessary will take a careful balancing using these techniques.
Variables that can probably be altered include:
Injection timing
Using vehicle tuning software or eventually chip tuning
Modify engine temperature sensor (may also affect glow plug function)
Injection duration
Modifying Injector Pump
Modify fuel temp signal (possibly only increase duration and may affect other variables possibly retard timing?)
Modify fuel plunger position sensor signal
Injection rate
Increase pop pressure (also affects spray pattern)
Bigger nozzles (also effect delivered amount?)
Peak Injection Pressures
Use a bigger pump from a later model/bigger engine – common performance modification (also affects rate?)
Glow plugs
Modify coolant temp sensor signal to increase duration, also I think I recall that at least on some models (if not all) they will switch on at below 2500rpm below a certain temp.
Engine heat
There is a standard option for a three glow plug coolant heater on some models.
Fitting a higher temp rated coolant thermostat
Air heat
Add intercooler ‘blind’ (Or increase intercooler size to reduce heat)
Electric heater in air ducting
Egr function
Manual modification/disablement (may require signal alteration)
Modify sensor signal or other control (vacuum?)
Position of Injector
Testing has shown a higher injector position (shimming out the injector from its seat) increases NOx (and hence engine temp and/or fuel combustability)
Fuelling quantities at start
Fuel temperature
Coolant and/or electric heaters
Air volume
Larger turbo chargers are regularly used as a performance modification
More Boost - various ways of obtaining common performance mod (will also increase delivery duration?)
Before performing any modifications I will be
checking vehicle health - njector spray, compression, controls/ sensors functioning correctly/within perameters.
Adding additional sensors that may include:
glow plugs as ‘thermocouples’ for cylinder temps
block temp
fuel blend sensor
exhaust pyrometer
knock sensor?
Dynometer (or ECU logging power calculations)
fuel vacuum
fuel pipe/injector temp
exhaust gas
All the above comes from much research by myself and others who have generally offered their knowledge to the public domain via the internet.
I think its going to be a fairly involved project and I do have a limited amount of time to progress with this. I am however planning to set this up as an open source development; I will hopefully have a discussion forum up and running shortly to facilitate such development. In the mean time I welcome suggestions/critique.
Best regards
Darren Hill
Injection timing
Injection duration
Injection rate
Glow plugs
Engine heat
Air heat
Egr function
Fuel temperature
Air volume
block temp
fuel blend sensor
exhaust pyrometer
knock sensor?
fuel vacuum
exhaust gas
Best regards
Darren Hill
