wjdell
So many question if there UOA sample was contaminated. For the price of one UOA you can be sure all your samples are accurate. Any good pipe fittings store can supply you will all you need to take fool proof oil samples.
PARTS LIST
1 Two way ball valve make it a 90* type not a 360* valve.
1 1/8" Tee fitting
2 1/8” nipples – 1 short to attach T fitting to oil filter housing, If you need clearance the second one can be longer if needed.
1 1/8' compression fitting in top of ball valve for copper tubing.
1 1/8” x 5” piece of copper tubing to shape as faucet. That might be the hard part if you have no tubing and do not want a whole roll you may be able to buy a small piece from a A/C or refrigeration repair shop.
1 Roll of Teflon tape – be careful do not get tape past the fitting. On new fittings wrap threads only twice.
Use brass or stainless do not use galvanized fittings. For around 15 USD you can sample your oil anytime and anywhere. When you need a sample just run 2 oz. through the valve which can be put back in the engine if your container is clean. This is a flush, then put your 3 or 4 oz of clean hot oil into your sample container.[FONT=Arial, sans-serif]
[/FONT]
PARTS LIST
1 1/8" Tee fitting
[/FONT]
