I am going to tap into my pressure sensor and using a restrictor make an oil manifold for my cam. The one question i have what thread is the sensor? does anyone sell a t fitting for the sensor port?
This is a good idea. Lycoming aircraft engines have a similar problem with cam wear. A noted rebuilder makes an oiling modification to improve cam lubrication.
yah i dont think it will hurt anything aslong as im not killing oil pressure. I am thinking about making it as simple as driling 8 small holes in a copper line that runs through the valve cover and cap it off somehow or just pinch the end. I could also make something fancy at work like a rail but mounting may be a problem.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
