beingdrained
I have a really strange electrical issue with an 02 Golf. Most of the time it's fine. On occasion, it will have nearly killed the battery overnight, and it will be re-locking random doors at random intervals. I'm not sure if this is the cause of the problem, or a result of it. I've never caught it doing this after parking it, so I think it's either starting much later or only when the battery gets drained. Once it's started doing this, it will not stop until the battery is disconnected for a bit.
The only thing that's happened to the car recently is that several months ago I replaced the driver's side rear door. The original door has power window and lock, the replacement has power window but not lock. It seems like the issue could be related, but if it is why will it not happen for weeks at a time, then happen, and then maybe happen again the next day?
I've looked at various other issues people have had with both battery drain and door locks, but nothing seems to match up to this set of symptoms at all. Because it's so intermittent and unpredictable, it's very hard to chase down. I've set the door latch for a few hours and then done a parasitic draw test on the fuse box a few times, and nothing seemed out of the ordinary, but it may well be that the issue simply didn't happen to get triggered on those occasions. I'm mostly looking to see if anyone's seen this specific sort of issue before so that I can try to narrow the cause down in a more meaningful way.
