Bad starter.
Maybe not your problem, but it was mine.
Drove to work on Monday, had been on the FrostHeater for a few hours as usual, not the most rapid spin on the starter as usual, just another long neglected 275k+ tired low compression cold start,...as usual.
Get in after work, no plug in, but air temp up to nearly freezing / melting, wait for the glow indicator and ....nothing. A very faint click and that's it. No attempt at the starter solenoid even trying to pull in which would have been a louder click, let alone engage the flywheel and struggle to spin the crank.
Key off, key on to try again. Faint click and nothing else. Once more, faint click. This time I held the key in start position and released the clutch pedal and pressed it again. That same faint click was heard each time the pedal hit the floor, so it's not the clutch interlock.
Push started the car and drove home. Got home and parked, engine is up to temp, the interior is up to temp, key off and try to start. A faint click and that's it.
Yesterday I rolled down the drive to bump start (rather than use muscle to push start) and parked on a hill near work. Bought a starter after work, installed it last night (2 hours). Starts right up.
This morning... I can't believe how well the car starts (4F, -15C). It's like it didn't start but was more like it is running, no cranking duration, no "Rur, Rur, Rur" of multiple rotations before it self-sustains, just turn the key and it is running. It was off and then it was running almost without any start in between.
