DarrenUK
My 1999 skoda octavia (vw golf platform) has been sitting for a few months. Went to start it last week and it cranked fine but would not fire. Tried to start it untill the battery drained.
Went back to it last night with tools and vagcom. Put jump leads on it and connected vag-com showed "17970 - Quantity Adjuster (N146): Upper Limit Reached P1562 - 35-00 - -" cleared code and tried to start. No joy. Tried to bleed it at the injectors and was getting fuel to all injectors.
Tried playing with the cold start 'adaption 5' tried at max value and some low values no help.
Noticed that after clearing the code and turning the ignition off and back on the code would come again without cranking after the ignition was turned on for30ish seconds
Any suggestions? I've done a search. The car was running fine before it sat.
I'll test the ohms at the pump connections 5 and 6 and see what I get.
