Here is a full VCDS scan if it helps...
Monday,05,May,2014,12:58:05:29260
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: 3VWST71K25 License Plate: ABC123
Mileage: 158880km-98723mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 47 52 56 62 72 7D
VIN: 3VWST71K25M631794 Mileage: 158880km/98723miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E1718592
Coding: 0050078
Shop #: WSC 01814 128 53366
VCID: 64E94953A729F33E1FF-8031
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 042 H HW: 02E 927 770 AD
Component: GSG DSG 041 0905
Revision: 04004010 Serial number: 00000502010346
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 18112DA32BE1E7DE437-804D
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 3A55D72B752DD5CE953-806F
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6CF921734FF9BB7E57F-8039
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000060327
Coding: F4098E02400418000014000000140000002077035C
VCID: 2F43F67FBE6F006632D-807A
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD01KZKX
Coding: 0012627
VCID: 2E7DEB7BB965096E39B-807B
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME087A6063B
Subsystem 3 - Serial number: 6342MSME087B0D17J
Subsystem 4 - Serial number: 6351HSME0639403E6
Subsystem 5 - Serial number: 6361HSME06316810-
Subsystem 6 - Serial number: 63727SME065A0624-
Subsystem 7 - Serial number: 63827SME0643261A-
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AB HW: 1K0 953 549 AB
Component: J0527 010 0045
Coding: 0010041
VCID: 72C53F0B6DDD6D8E9D3-8027
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 971 D
Component: KOMBIINSTRUMENT 3HL 2120
Coding: 0023203
VCID: 2C79E1738F797B7E17F-8079
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 27001051230362
Coding: 3F3F0B420F1002
VCID: 29771867808B6E56EC9-807C
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 9
Reset counter: 220
Mileage: 158886 km
Time Indication: 0
Date: 2000.00.00
Time: 12:21:51
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TNTQK03
VCID: F8D18D238BA187DE237-80AD
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2120
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001271
VCID: 364DC31B413531AE71B-8063
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.3 1502
VCID: 3041F503A3511F9E2B7-8065
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13100F880106281B0906050FA0080F0490A540
VCID: 8225EFCBDD7DDD0E0D3-80D7
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1K6 035 456
Component: 08K Audioverst. 0003
Revision: 00002000 Serial number: 00000000022730
VCID: E9F7D867C00B2E56AC9-80BC
1 Fault Found:
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001271
VCID: 3753CE1F463FC8A66AD-8062
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7K1111242
Coding: 2100040004
Shop #: WSC 01357 011 00200
VCID: 61E74047783BE616F49-8034
5 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 158886 km
Time Indication: 0
Date: 2000.15.00
Time: 12:19:47
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 158886 km
Time Indication: 0
Date: 2000.15.00
Time: 12:23:32
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 158886 km
Time Indication: 0
Date: 2000.15.00
Time: 12:23:32
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 158886 km
Time Indication: 0
Date: 2000.15.00
Time: 12:23:32
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 220
Mileage: 158886 km
Time Indication: 0
Date: 2000.15.00
Time: 12:23:32
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 3147F007A85B1696249-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 3245FF0BAD5D2D8E5D3-8067
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D7FEC77B4637276001-8078
End ---------------------------------------------------------------------
