shizzler
There's not much really information out there to help you figure out where the separation point actually is. Read this thread to see how I tested and went forward with my own VG installation. The tuft test seemed pretty clear to me.
http://ecomodder.com/forum/showthre...z-vortex-generators-2003-jetta-rear-8839.html
BTW woodrobin, get used to explaining what those "shark fins" are on your car to every joe schmoe who gets curious.
Oh and per your injector leak.... sad to say but it probably does have everything to do with your abrupt and recent switch to pure biodiesel. Biodiesel makes fuel lines and seals swell (and switching back to pure dino-diesel will make them contract again). More often leaks occur when you switch back to regular diesel, but it can happen the other way too. Looks like the injector return line (rubber tubing inside of fabric weave) is leaking... it probably swelled up and got loose on the metal injector. Good news is the return fuel line assembly should be cheap and easy to replace.
If you do try to tighten the fuel line atop the injector to rule that out, make sure to counter-hold the injector so you aren't twisting it too. Don't go overboard....
As a general rule, I try to always gradually shift from lower to higher blends of biodiesel. But I also now try to never run pure diesel (my stuff leaks too sometimes). I would recommend you do the same now that you blew everything out with pure bio. I also think I'll stay under B80 from now on to hopefully avoid any further leaks and required fixes or line replacements.
