Engine has developed what I'd describe as a "metallic drone".
When I remove the serpentine belt the sounds goes away.
I haven't been able to pin-point which component it's coming from.
When I spin all the pulleys in the system I don't hear or feel any usual noises/grinding, etc
I replaced the tensioner/shock and alternator pulley when I did the timing belt couple years ago. Had a shop rebuild the alternator at the same time.
The A/C compressor was replaced by the previous owner with some non-OEM deal. The AC hasn't worked in months, 99% sure it's just the clutch coil that has died. Just haven't had the time to deal with it. spins fine.
So the only original components are the power steering pump and the serpentine "roller".
Power steering pump is topped off, doesn't make any odd noises when turning the wheel. Loses no fluid. When I spin the pulley it sounds fine/no grinding, but it doesn't spin very long... maybe 1.5-2x around. compared to the other components which I'd guess spin 4-5X around. My gut says it should be the culprit, but with my ear near it, I don't hear the noise really any louder... and I hate to just throw money/new parts at the problem hoping it'll do it...
Any good advice/tricks to track down the culprit?
