lol sure! Thanks for taking a stab at ittrue...and your hitch is square tube and the hidden hitch is round.....i could have swore his was square, but i guess im wrong.
Can I get a Participation Ribbon? lol
Will do, but it's incredibly jammed. I'd love to soak it in some ATF but I don't have a basin of ATF kicking aroundoh yeah, now that you pointed it out I see the differences. I'll keep an eye out for ya. If you haven't already tried it you might want to do a couple hot/cold cycles on the pin. If you put a propane torch to the pin it might crack the rust enough for the hydraulic press to work.
I actually have another hitch kicking around - i'd just really rather not redrill the bodyThere's really only a handful of hitch companies. None of them appear to make exactly what you had from what I can see. I'd almost suspect that you have an older version of the Hidden Hitch as the design is nearly identical.
That said you should be able to get a new one made to match your old one. Just will probably cost a bit more than an off the shelf pre-made one.
