roadhard1960
I have my Mity Vac with a vinyl hose. I put my finger on the hose and pump to about 25" and it holds that vacuum. I attach it to the black port on the N75 and put my finger on the two white ports. It bleeds down pretty fast. Is the N75 supposed to hold a vacuum in this test? I would hope so as it would seem that the device at the end of the white ports would not getting the proper amount of vacuum. I also tried to attach the vacuum to the large white port and cover the remaining ports and I get the same quick leakdown. That would be about 4 seconds to go from 20" to zero. Note that the Mity Vac cannot get 25" like it does with the finger test.
I am wondering if my weird throttle stuff that I did not notice 150,000 miles ago when I had the car chipped is related to this N75 having an internal vacuum leak.
