My 97 Passat that I just picked up has been throwing a CEL and going in and out of limp mode. Sometimes the car runs great, then at others it just falls flat on it's face. Hooked up my Rosstech cable and pulled the code :
01269 Commencement Of Injection Valve (N108) 31-10 OPEN OR SHORT TO GROUND INTERMITTENT
I located the N108 valve on the bottom of the injection pump and inspected the wiring for any frayed or broken wiring, and couldn't see anything physically wrong with the wiring. I haven't had time to check for continuity from the plug to wherever it pins out on the ECU harness, but that's probably my next step.
I have a spare injection pump with a N108 valve on it, but from looking at where it's at on the pump and in the car, it might be a bit of a hassle to change out in the car, if it turns out the wiring is indeed OK.
So, has anyone ever changed this out on the car or does the injection pump have to come off? Also if it can be changed in the car, will this require the fuel system to be purged since I'm guessing pulling the valve out will introduce air into the system.
