AleeexPass
Hello people.
I have a passat 1.9 avb. Can handle 2.5 bar ? I have 2260vk turbo, big fmic, firad 160%, 76mm exhaust.
No! AVB has a very weak crankshaft, connecting rods and pistons!Hello people.
Kimmo, nyt se korkki kiinni!Boost isn´t factor which affects for engine durability, you can boost 5 bars if you like without problems, but not with that tiny turbo. Cylinder pressure, EMP and temperatures affects.
AVB has a very tough crankshaft, connecting rods and pistons.
AVB has same crankshaft as AVX and AVF. AVB connecting rods and pistons can handle 400hp/600Nm if everything made properly. AVX/AVF pistons and rods are ~10% more durable than AVB. Forget boost pressure and focus on air flow instead. Boost is not air flow.
