Golf_GTDI
Well, here are the first pics. Jon was kind enough to not even open the boxes that Petr (VW4motion) sent me from Prague so it was like Xmas come early yesterday. In the boxes were the Audi LCAs, Spindles with front binders as well as an 11mm pump. Can you say yummy boys and girls? Knew ya could!
Here are the parts...
Here are the front spindles with brakes. I asked for VR6 brakes but these things are just monsters. 312mm if I had to guess which means I may (may) be able to get away with 16" wheels but 17s may be a better idea due to better choice of wheels and tires in that size at fiar price points. Then again I may just ditch them and stay with the VR6 setup. Stay tuned to find out.
Here are my Audi TT/R32 LCAs. As you can see they are very different than what comes stock. We did not weight them to this point but I do think they weigh a bit more. They are however adjustable and can give a bit more negative camber in addition to what the TT spindles do by design.
This is some detail of the LCAs. Right now I am unsure if these are the same as what we get here in the states but I am somewhat hopeful that these are the now outlawed old school Euro LCAs that are now highly sought after by the TT guys. I need to do a bit of digging on this subject.
I was also happy to see that my LCAs have the area that can be easily drilled for a front sway bar. I am however pondering going with the TT front PSS9 kit with an Audi TT front sway. This mounts on the inside of the shock body and not on the LCA itself. Once again stay tuned and or feel free to kick in your thoughts on this.
This is the 11mm pump that will be feeding my TDI with all of its other newer go faster goodies. Its due to all of this that makes me feel the need to turn better and stop faster. My aim is to build a very quick and well balanced car that does most things rahter well with as few as possible shortcomings.
Its my plan to update this thread with updates in regard to the install and choices in setup. Feel free to ask questions or leave feedback in hopes of making this a bit of a resource for this sort of upgrade.
