Hi, so, I'm new to all this, but learning.
Right about the time I confirmed that my MPG is not what it should be (<30mpg), my engine threw a code P0117, which I guess is a coolant temperature sensor. Reading online, they said symptoms include poor performance at low temperatures, hard starting, and poor mpg -- check, check, check. I also recently replaced the lift pump and the fuel filter, and when I did that, I noticed that my engine sure shakes around in there when its running. I found a video that suggests I get into the cylinder head and clean the injector wire contacts in case that helps correct any misfires. I also heard that maybe I should clean the EGR valve and maybe the MAS as well. Also, I have a new air filter coming just for good measure (I just bought this car used -- it came with a scanguage).
My questions are: 1.) Any advice for replacing the ECT sensor? I found a video, it looks messy. But I'm up for it. 2.) Any other advice for what else I should check for regarding poor MPG? Or do you think this all might fix it? Any other advice for a rough-running engine (it gets much much smoother when its warm)?
Thanks!
Thanks!
