More TIming Questions
go_tdi
fallsington, pa usa
12 Golf, 04 Jetta
Just changed my timing belt, cleaned intercooler, and replaced turbo. I was checking with VAG-com 2/9 basic blocks 51/151 is this Okay. What do these numbers represent?
FYI.... turbo went bad, pumped 1 quart of oil into intake.... what a mess
TDI-passat
Z'zee,The Netherlands
Passat 1997 TDI Marine blue
See under articles A3 timing belt replacement. There is a lot of information you need to know.
Search the forum for the graph-chart of the timing. It is posted more than once.
go_tdi
fallsington, pa usa
12 Golf, 04 Jetta
changed the timing this morning its now 12/140.
if anyone can post the chart or a link to a thread with a chart that would be helpful.
go_tdi
fallsington, pa usa
12 Golf, 04 Jetta
Thanks for the timing graph wolfsburg_de.
As it stands right now I’ve had a very expensive week. It looks like not only did the turbo self destruct but so did 3 of the 4 glow plugs. After pulling the temp sensor and letting it glow for 15 seconds it would try to run on 1 1/2 cylinders. 3 of the plugs read infinity, one reads 0.05 ohms. Four is the number of plugs that are being replaced as soon as my parts guy Willy can get them to me!!!
Once again THANKS To all!
Rob H
