Tony Soprano 1966
Guys,I have yet another electrical problem on my Golf MK5,if I dont drive the car for a couple of days,battery is flat and I have to use a booster pack to start it.
Dont know if it is connected,but I had a rear ABS sensor replaced just before the problem started,although I had noticed before that was done, that it was starting to be bit slow to turn over from cold.
The battery is a Varta,and was new about 5 or 6 years ago.
Where do I start with this problem?alternator? starter motor? failing battery?
Or the dreaded parasitic drain?will post any VCDS DTC`S later.
