sdean7855
Hoping to tap into the collective wisdom.
Background:
I had my original dual-mass clutch replaced at about 375K miles; I had to stomp the clutch all the way to the floor to shift. My reasonably reliable mechanic (mech#1) replaced it with a single mass. I had some subsequent problems (shifting was very difficult) which another mech (mech #2) determined was that one of the starter bolt had worked free, losing the bolt and a wire loom retention bracket. The main 150A cable from the generator then rubbed up against part of the shifter, making shifting hard and eventually chewing into the 150A main cable and blowing the 150A fusible link (alternator light came on crossing the GW bridge into Manhattan and wasn't it fun getting the car home). New mech got that sorted out....but a clean shift still requires the clutch go all the way to the floor....lift the clutch at all and immediately hear the engine start to load. Went over things with mech #1 who said he checked the clutch throwout lever and its plastic pivot point, also replaced the slave cylinder, bled and topped the hydraulics.
Questions:
I've included images of the battle of electrical cables vs. the shifter as cautionary info...
Background:
Questions:
- Any suggestions for what else might be wrong?
- Do single mass clutches requires more clutch pedal?
- Does a double mass to single mass switch require any addition changes/part beyond the clutch disc? A different throwout lever, etc.?
