apples12
Hi all
I retrofitted OEM bi-xenon's with AFS to my Mk6 about a month ago...
for the last month they have been working GREAT! apart from the bulb out light on the dash and no flash to pass when the headlights were off...
This was due to the fact i had an 086 BCM module which had old software which didnt support these features...
fast forward a month...
i have a 087 module which with much knuckle scraping i managed to get into the car, code my remotes with it and rest of the features and away i was...or so i thought
for some reason the shutters are no longer working! the cables are all still intact, wiring is fine, just no shutters moving which means whilst low beams are on, i have no high beams... (these are used surprisingly a lot when i am doing country lane driving)
can anyone shed some light on this issue?! (no pun intended!)
many thanks
update:
if anyone comes across this, in order to have fully functioning bi-xenons on a mk6 golf platform, i.e. flash to pass with the headlights off, shutters working properly etc etc, you MUST have a software index of version '0525' or higher, it does NOT matter if you have a '086' or '087' BCM version, the software version is more important
enjoy!
many thanks
update:
enjoy!
