G3TDI
Ever since I ran across the TopGear's Rabbit Sipster project I have wanted to do something similar.
5 Part Article can be found here:
http://www.motoiq.com/magazine_articles/articletype/categoryview/categoryid/139/project-sipster.aspx
Videos can be found here
http://www.bbcamerica.com/shows/topgear/video.jsp?bclid=31560306001&bctid=30115379001
All gathered together here:
http://rabbitsipster.blogspot.com/
I was pretty sure I didn't want to start with a Mk1 (Rabbit) as they did, just because I want this to be a daily driver etc. So I first was considering to do a Mk2 and in fact started this thread on this other forum:
http://ecomodder.com/forum/showthread.php/big-bumper-small-vw-golf-mk2-12384.html
I have since changed this plan to a Mk3 mainly from learning from the ecomodder forums how little role the weight plays and how much the aerodynamics does! I figure I can lower the weight on a Mk3 much easier than making a Mk1 & Mk2 more aerodynamic
Mk1 Weight 1918 lbs (870 Kg) Drag: 0.42
Mk2 Weight 2026 lbs (920 Kg) Drag: 0.34
Mk3 Weight 2387 lbs (1084 Kg) Drag: 0.30
But more importantly I learned that Cd is only half of the story (if even half
) cause I found this info:
Mk 1 Cd.A = 0.83
Mk 2 Cd.A = 0.70
Mk 3 Cd.A = 0.66
Mk 4 Cd.A = 0.70
Mk 5 Cd.A = 0.76
here: http://www.clubgti.co.uk/forum/showthread.php?p=1761101
Now that I have introduced my ideas, and project I can add to this now that I have just recently bought a 1994 Golf (2.0 ABA) & a 1998 TDI Jetta. So I am ready to start this now, did some of the homework tonight and found out that the Rabbit sipster used an ALH engine but an AHU transmission apparently ".... and an 02A five-speed transmission from a '98 TDI (the '98s had taller gearing that will help with our mileage goals"
http://www.motoiq.com/magazine_arti...oject-sipster-part-2--the-road-to-regina.aspx
Now I would like to know what you TDIclub guys think of this:
That's a screen shot from the video linked to above, now that is apparently a chipped ALH, however to keep it simple I chose to go the route of doing a Mk3 Jetta TDI -> Mk3 Golf. So what would the best performance improvements be for the AHU with best MPGs in mind?
By the way my goal is 70-80MPG!
P.S. Here is a pic of a nice Mk3 I ran across that has been inspiring to this project, as I do plan on lowering it and maybe remove ext mirrors
Mk 1 Cd.A = 0.83
Mk 2 Cd.A = 0.70
Mk 3 Cd.A = 0.66
Mk 4 Cd.A = 0.70
Mk 5 Cd.A = 0.76
