LOL that pretty much sums up my thoughts on it as well. Where is the Big Arnie Dog when you need him? No doubt he has some classic pics to add as well.NB_TDi said:
Yep, I found myself in the same position after reading this thread ...... but while reading the OP, I WAS YELLING:NB_TDi said:
I am not advocating the use of used engine oil in fuel, however information is your best friend, and it reduces the risk of misfueling. For instance, I and many others know what we are doing when we run B100 on the ALH and PD engines. The risk is no different or even lower than getting bad diesel fuel from a commercial source.Tom W. said:On the 1.9 (pictured) I will run only B2 (2% biodiesel) or 100% diesel with dieselkleen. Why take a chance on such a high priced engine?
Why I love TDI CLUB. I think experience is your best friend- information gleaned from experience of others can be your 2nd best friend. Obviously, You and others running on B100 have the experience- and hard-won knowledge- to be comfortable running B100.UFO said:I am not advocating the use of used engine oil in fuel, however information is your best friend, and it reduces the risk of misfueling. For instance, I and many others know what we are doing when we run B100 on the ALH and PD engines. The risk is no different or even lower than getting bad diesel fuel from a commercial source.
Edit: I just noticed bigarnie's graphic - OMG!
I think you're confusing WVO and B100. B100 should be totally fine to fill any good running TDI's tank - so long as you keep an extra fuel filter handy.Tom W. said:Why I love TDI CLUB. I think experience is your best friend- information gleaned from experience of others can be your 2nd best friend. Obviously, You and others running on B100 have the experience- and hard-won knowledge- to be comfortable running B100.
Actually, I've run WVO since 2001- long before most people even heard of the idea. - You'd be suprised what these old 1.6 IDI's can successfully run on- IF you know what you're doing.WVU TDI said:I think you're confusing WVO and B100. B100 should be totally fine to fill any good running TDI's tank - so long as you keep an extra fuel filter handy.
WVU TDI said:The proper mix ratio is 0 parts waste motor oil to 5,000,000,000 parts diesel fuel.
I'm waiting for time to tell, but I think this late into the game if your IP seals were gonna give you fits they should have already done so with the ULSD push.scythefwd said:Just as a side note, if you are running B100, keep an eye on your fuel lines and seals on your IP. B100 is a very strong solvent and while your fuel lines should be fine (my 99's lines might need to be upgraded to vitton) your seals may not be if you switch back and forth between dino and bio diesel.
So basically don't put more than 20% diesel into the rig and no worries, gotchascythefwd said:kcfoxie - going from usld or lsd to bio is a non issue, its the switch back that does it if I remember right. I think the bio causes the seals to swell and going back to usld/lsd causes them to shrink and leak. I have never ran more than b20 in the car and I don't worry about it... but some people have experienced it.
That is not what I am saying. I am saying don't go switching back and forth from using high concentrations of biodiesel to using straight D2. If you are going to use high concentrations (some people say as low as B5 is enough to do this) of biodiesel, stick to using that and do not go back to running d2 or you may have problems.kcfoxie said:So basically don't put more than 20% diesel into the rig and no worries, gotcha
What about your catalytic converter and the entire exhaust system? Have you pulled the EGR to see how much CRUD buildup there is in there?maniaq said:always burn my use engine oil in my tdi 2000, still running fine, same fuel pump same injectors, the engine don't smoke at all. 280 000 mile on it. i add 250 ml in a full tank (around 50L). fuel economy is between 40-45 mpg. i did not know that doing this is hard on the fuel injection system.
