Haz-matt
I think I have an injector failing on me. Or at least the car thinks it's failing.
Car has been throwing a low volume EGR error off and on, but it hasn't affected anything and I've been too sick to work on the exhaust side.
But now it's saying the #1 hole is misfiring. I can clear the code after it happens and it runs, stumbles a little but eventually throws the code again. Glad I was close to home and the power outlet was still working so I could get the scan.
Based on the scan or anything else you know, should I be looking at pulling the #1 injector and getting it rebuilt or replaced? Or should I be looking at something else?
Monday,30,September,2013,11:38:56:58551
VCDS Version: Release 11.11.5
Address 01: Engine Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 997 016 P HW: 03L 906 022 J
Component and/or Version: R4 2,0L EDC G000AG 8681
Software Coding: 0050078
Work Shop Code: WSC 00066 000 00000
VCID: 3FA399876E990BE0186
2 Faults Found:
001025 - EGR System
P0401 - 000 - Insufficient Flow - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 46
Mileage: 287568 km
Time Indication: 0
Date: 2000.00.00
Time: 23:26:15
Freeze Frame:
RPM: 1449 /min
Speed: 45.0 km/h
Voltage: 13.83 V
Load: 90.2 %
Load: 100.0 %
Mass Air / Rev.: 315.0 mg/str
Mass Air / Rev.: 410.0 mg/str
004663 - Fuel Injector for Cylinder 1 (N30)
P1237 - 000 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 290417 km
Time Indication: 0
Date: 2000.00.00
Time: 23:22:43
Freeze Frame:
RPM: 2047 /min
Speed: 104.0 km/h
Voltage: 14.06 V
Temperature: 25.2°C
Temperature: 21.6°C
Inj. Quantity: 8.8 mg/str
Bin. Bits: 0011000
Readiness: 1 1 0 0 0
Monday,30,September,2013,11:41:33:58551
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 AE HW: 1K0 907 379 AE
Component and/or Version: ESP MK60EC1 H35 0106
Software Coding: 113B400D492600FC880C02E6921F0042B100
VCID: 75CF3BAFDC2581B002A
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 290417 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8193
Count: 51048
Count: 6
Count: 0
Count: 0
Monday,30,September,2013,15:18:39:58551
1 Fault Found:
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 290437 km
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 0
Count: 13056
Count: 8193
Count: 50176
Count: 2
Count: 0
Count: 1536
2 Faults Found:
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 46
Mileage: 287568 km
Time Indication: 0
Date: 2000.00.00
Time: 23:26:15
Freeze Frame:
RPM: 1449 /min
Speed: 45.0 km/h
Voltage: 13.83 V
Load: 90.2 %
Load: 100.0 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 290417 km
Time Indication: 0
Date: 2000.00.00
Time: 23:22:43
Freeze Frame:
RPM: 2047 /min
Speed: 104.0 km/h
Voltage: 14.06 V
Temperature: 25.2°C
Temperature: 21.6°C
Bin. Bits: 0011000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 5
Mileage: 290417 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8193
Count: 51048
Count: 6
Count: 0
Count: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 290437 km
Time Indication: 0
Freeze Frame:
Count: 16387
Count: 0
Count: 13056
Count: 8193
Count: 50176
Count: 2
Count: 0
Count: 1536
