pogo
Microreactor for distributed production of Biodiesel
21 February 2006
The microreactor. Click to enlarge. Chemical engineering researchers at Oregon State University have developed a microreactor for biodiesel production that promises to be efficient, fast and portable, and are looking for commercialization partners.
The microreactor, developed in association with the Oregon Nanoscience and Microtechnologies Institute (ONAMI), consists of a series of parallel channels, each smaller than a human hair, through which vegetable oil and alcohol are pumped simultaneously. At such a small scale the chemical reaction that converts the oil into biodiesel is extremely rapid.
Conventional biodiesel production methods involve dissolving a catalyst, such as sodium hydroxide, in alcohol, then agitating the alcohol mixture with vegetable oil in large vats for two hours. The liquid then sits while a slow chemical reaction occurs, creating biodiesel and glycerin, a byproduct that is separated. This glycerin can be used to make soaps, but first the catalyst in it must be neutralized and removed using hydrochloric acid.
The microreactors can produce biodiesel between 10 and 100 times faster than traditional methods, according to Jovanovic, who is also developing a method for coating the microchannels with a non-toxic metallic catalyst. This would eliminate the need for the dissolved chemical catalyst, making the production process even simpler.
Although the amount of biodiesel produced from a single microreactor is a trickle, the reactors can be connected and stacked in banks to increase production. A device the size of a small suitcase could produce hundreds of thousands of gallons per year, according to Jovanovic.
21 February 2006
