audibahn
Were you all able to resolve this issue? I have the same problem. The gauge was working fine for a while and then started reading over the actual pressure. The delta was still accurate, but I could only wish I was pushing 25 or more PSI
Interesting thing is that the gauge was stuck at 10PSI last night. Turned the car off and came back the next morning with the gauge still at 10PSI. I then removed the connector at the transducer under the hood and reconnected which reset the gauge back to 0.
Any suggestions?
Any suggestions?
