jetta 97
Here is spec. of all manual transmissions fluids from old beetle to 2009 vw.
1.up to 1992 all vw regular GL-4
2.from 1993-1999 mk3 G50 synt. 75w-90 part no. G 005 000
3.1999+ 5 speed part no. was G0 52 726 A2 and update to G0 60 726 A2
4. 2002- 2009 most 6 speed(need check by vin or trans. code)
part no. Go 52 171 A2
5.2006+ most models(again need check by vin or trans. code) and wagon mk4
Part no. was G0 55 726 A2 update to G0 70 726 A2
All fluids runs from $15-$25 ,except G0 52 171 A2 which is around $35-$40,depending on State.
All fluids should be replace about every 100k unless you have update on fluid.
For example if you have 05 jetta 5 speed and you have 65k ,your original fluid was G0 52 726 A2 and you should change to G0 60 726 A2.
Only 6 speed need to be change every 80k.
Red line MT-90 or MTL 70w-80 is alternate fluid for VW transmissions but I would stick with original fluid. It is not big different in price but if your transmission go bad ,it is big price to fix it.
