Since when are manhole covers 6 inches off the ground? That's a public safety hazard. I don't even hit the parking stops. I have more than plenty of ground clearance and I will take pics to prove it. You don't know *** you're talking about. PERIOD!
With the exception of 4x4's, most people who modify their suspension LOWER their cars. Why? It handles better, it looks better and is FAR from rice. People have been lowering their cars for over 7 DECADES.. long before "rice" was used to describe Japanese imports.
Look at the suspension companies. Eibach, Koni, Bilstein just to name a few... they lower cars because it looks good and performs. When VW, Toyota, Ford, Chevy, BMW, Nissan offer "sport suspension", what do they do? They LOWER the car. Millions of people are not wrong. YOU ARE WRONG!
You FAIL ON MANY LEVELS!
GTFO of lowering posts and crawl back in your hole. Go troll somewhere else.
I guess you can't read either. Neither of us said "slammed" and a 1" drop doesn't qualify as slammed. That sucks for the vortex guy but none of us are contemplating ground clearance of less than 2". READING HELPS!!!I guess you didn't see the thread on vortex that a guy with his slammed MK4 2 door Golf got totaled it because he hit a manhole cover that was 2in off the ground. Took out the subframe and blew out the airbags. Could have killed him. Car went to the junkyard.
It handles better lower??? ROFL! I guess you don't realize that a MK4 is actually faster on the track lifted because the suspension can work better.
I am a troll? I think I am just pointing out the reality of lowing your car.
I think YOU are the one who refuses to realise the realitiy and is living in your own little world.
which brand is best:
Vogtland
Eibach
Apex
I have found a set of each, the Eibach's are NIB, the other ones are used
The 15ft leading to my new shop is so rough that no lowered vehicles will be able to get to my driveway. Thank god! You "lower it" folks are always full of attitude and lip. Good luck.
Quoted for emphasis!!Got Bearings, you can lower your car, I won't try to stop you. However, your misinformation is rampant as are your unprovoked shots at turbocharged798.
it appears this is a hot issue. i was only thinking of lowering 1.5". what else do i need besides springs?
Troll much?^ the irony is better that you don't understand it
oh, the irony gets better.Troll much?
Most importantly- Men buy for sport, women buy for looks
I have a question for you and no I'm not for lowered or raised cars for that matter. If the axle path on both the lowered and stock ride heights stay the same since you are not replacing control arms, how could it change steering geometry? So if the OP did his research and bought springs with a spring rate that was the same progression as stock springs at 1" of compression wouldn't the end stroke of compression be almost identical while cornering hard. I am just wondering these things because I rebuild suspension for other aplications and if the OP is not replacing the linkage that it should not negatively affect the ride except for ride comfort and small bump absorbtion.Since I'm too "stupid" to understand what I've done wrong, would you please clarify?
I'm quite sure that I have not insulted, disrupted, or de-railed this thread.
Did I "dumb-down" your thread by pointing out steering geomety reality?
I've just found something that is much better and is less than 1/4 the cost!What should we get if we really want to go fast? Audi TT LCA bushings, Audi TT subframe bushings, TT roadster brace on the subframe, Neuspeed strut brace, sticky (expensive) tires on 17" wheels.
i was wondering the same. the GLI has 1" lower and stiffer springs, i know many that just add these and a sway bar to stop the oem body rollI have a question for you and no I'm not for lowered or raised cars for that matter. If the axle path on both the lowered and stock ride heights stay the same since you are not replacing control arms, how could it change steering geometry? So if the OP did his research and bought springs with a spring rate that was the same progression as stock springs at 1" of compression wouldn't the end stroke of compression be almost identical while cornering hard. I am just wondering these things because I rebuild suspension for other aplications and if the OP is not replacing the linkage that it should not negatively affect the ride except for ride comfort and small bump absorbtion.
Wow! I'm curious to know how well those work....I've just found something that is much better and is less than 1/4 the cost!
http://www.034motorsport.com/chassi...-aluminum-mk-chassis-vw-and-audi-p-21362.html
