josh higbee
So this recently started happening. I have a 2003 tdi 5spd and if you rev in neutral there’s no abnormal sound, if you flood it in first you can very faintly hear the sound, second gear you can still hear it faintly, but in 3rd 4th or 5th it’s REALLY obvious. The sound is hard to explain, kind of sounds like a fast slapping sound, does sound pretty close to what an engine knock would sound like. Took a look at everything and can’t see anything obvious. No smoke from tailpipes either. It follows rpm’s but seems to get to fast to notice above 3k rpm’s. Happens between around 1800-2600rpms. Any help would be appreciated
