Can you post a video? Does it tick constantly or only when it's hot or cold?Just piggyback on this thread a little bit, my alh has started ticking really loudly right after a long 200km+ drive. I had a look thinking I had an exhaust leak and sure enough my egr block off plate had a leak. I replaced that plate and gasket and I'm still getting really loud noise. I don't think it would be injection timing as it was working perfectly fine since I installed the engine 15000km ago. I just did an oil change with liqui moly 5w40 if that makes any difference
Its a freshly build engine with only 15000km on it since I did the swap into my van. The clacking started while I was driving and the engine was hot. There was an exhaust leak from the egr blockoff plate and I've fixed that. It sounds normal on video but it's just really loud.Can you post a video? Does it tick constantly or only when it's hot or cold?
Any chance you ever replaced the lifters?
If you rev, does the ticking also increase with the revs or stays the same?Ok so imgur doesn't have sound... Odd
Noisy alh
youtube.com
It increases with rpmIf you rev, does the ticking also increase with the revs or stays the same?
What do you mean by it "blew up"Well I re set the timing and my engine blew up mere moments later. I have no idea why as everything lined up with all the tdc marks and I had the cam setting bar all aligned. It's looking pretty likely that I'll need a new engine. On the plus side, I won't have to worry a out a noisy engine I guess
It started making a loud puffing noise then it seized completely. I can't even turn it over by handWhat do you mean by it "blew up"
I did everything according to the bently manual I have. One thing the bently doesn't have is combined experience of people who have gone through similar issues In the past, which is why Im posting on a 7 year old thread. And this engine I had to swap both the injection pump and bracket from my donor alh that I started with(this is the second engine I had, first one died when I was building the swap) so I've done the timing process before, and put 15000km on this engine before it blew up. I haven't opened the engine up yet but will keep you posted on what I findYou might want to "tighten-up" your timing and assembly skills on that next engine. Do you own a Bentley manual? Spend more time in the manual and less time behind a keyboard.
The only thing I saw was when I had the valve cover off for timing belts.Quite frankly, most of the guys who post on this forum never saw the inside of an alh. Lots ahh talk though.......
