RomanDiesel
Hello to all!
Today I managed to re-start my 2009 CBEA engine, after a HPFP failure (2nd time) and replacement. I primed as needed (2x10 minute of both pumps running) and I used some quick start spray to help.
When the engine started, I noted very rough idle and a lot of power missing. When I drive, the car shakes a lot. I drove more than 5 km, hoping that there is some air in the system and the symptoms will go away, but only little or no improvement. I used OBDeleven to scan and I share with you the codes:
1. Cylinder 4 Injection Timing
Fault code: P020D (525)
Status: Intermittent
Frequency counter: 3
Measurements:
1564 U/min
25 km/h
20.8 %
00100000
Mileage: 352649 km
Driving cycle: 255
Priority: 2
2. Torque difference cylinder 4
Limit value exceeded
Fault code: P1007 (4103)
Status: static
Frequency counter: 2
Measurements:
1725 U/min
27 km/h
24.7%
Mileage: 352649 km
Driving cycle: 255
Priority: 2
3. Cyl.4
Misfire Detected
Fault code: P0304 (722)
Status: static
Frequency counter: 1
Measurements:
805 U/min
0 km/h
10.4 mg/h
265 mg/h
Mileage: 352650 km
Driving cycle: 255
Priority: 2
4. Cylinder 3 Injection Timing
Fault code: P020C (524)
Measurements:
2116 U/min
0 km/h
25.5 %
00000001
Mileage: 352650 km
Driving cycle: 255
Priority: 2
Any ideas?
I did not change all system, only HPFP and good cleaning, as I did previous failure. At that previous failure, I had to change also the CR, because of faulty sensors on it.
Any help will be greatly appreciated!
Measurements:
1564 U/min
25 km/h
20.8 %
00100000
Mileage: 352649 km
Driving cycle: 255
Priority: 2
Status: static
Measurements:
1725 U/min
27 km/h
24.7%
Mileage: 352649 km
Driving cycle: 255
Priority: 2
3. Cyl.4
Misfire Detected
Status: static
Measurements:
805 U/min
0 km/h
10.4 mg/h
265 mg/h
Mileage: 352650 km
Driving cycle: 255
Priority: 2
Measurements:
2116 U/min
0 km/h
25.5 %
00000001
Mileage: 352650 km
Driving cycle: 255
Priority: 2
Any ideas?
