RESOLVED... for realz this time! ;-)
HI all,
I wanted to do a follow up post, as I have isolated and fixed the problem... it only took 3.5 months!
This noise has been very hard to diagnose because there were several other noises occuring simultaneously and concurrently with the normal turbo spooling whistle. This gave the impression that the leak was generating from airflow. However, the final underlying noise was mechanical. The only way to figure it out was to mic the engine after fixing each one and see what the noise differences told me.
I had both a private mechanic and a VW tech look at it, and both diagnosed the noise incorrectly. I gave them every bit of information about the car including mods, changes to the clutch, etc.. and they still misdiagnosed.
The noises so far have been:
- EGR Cooler
- Exahaust leak at the DP/CAT coupler
- Bad right front wheel bearing
- Normal turbo whistle
- Undetermined clutch noise
Exacerbated by:
- Trashed motor and transmission mounts
- Whining gear box
The final fix was to remove the Valeo SMF Kit and replace it with the dieselgeek LUK DMF.
Here are the clutches in order (Valeo, original Sachs, new LUK):
After the swap all the problems went away... it is smooth as silk now. I was amazed at the overall NVH reduction. The interior rattles have subsided tremendously, the pedals don't vibrate hardly at all, and the scraping-hissing-grinding noise during acceleration is 100% gone. The surging feeling when accelerating is gone. And now I can say, with certainty, that the delay in turbo kicking in, whicn I had noted felt like the clutch slipping, was in fact the clutch slipping. The engagement is smooth and perfect... not grabby at all like the Sach's was before I took it out.
Not sure if the clamping force on the Valeo clutch wasn't enough. I only have a stage 1 tune on my TDI. But, the back of the clutch disc looked to be glazed, and the wear marks on the front of the clutch seemed to only be on the very center and about 3/4" wide... so it looked like the pressure plate and clutch were only touching over a very small surface area. Also, the metal dowel-like pins on the very top of the pressure plate (9 of them) that hold the pressure fingers were all scraped and worn down. So they were rubbing on something. But, there was no indication of rubbing on the clutch fork at all.. so no clue where or how that happened.
Also, upon removing the transmission, a piece of the clutch fork retaining clip fell out. The clip had snapped.
Seeing as I was working on this last Saturday, I tried calling around to the dealerships (only 1 was open on Saturday and were an hour away... but they didn't have the clip in stock anyway), and some auto parts stores. No one had the clip. So I made one myself out of galvanized wire. It took me about 7 or 8 tries to get it right. But, it worked perfectly.
FINAL CLIP:
PROTOTYPES:
INSTALLED:
I also checked the springs in the clutch hub. There are 4 double coil packs. I plucked each one like a guitar string, and one of the coil packs reverberated and resonated the whole hub.
I think the Valeo flywheel was not balanced correctly either. I noticed welded balancing weights on the the back of the LUK flywheel. The build quality of the LUK is far superior to the Valeo, too... especially the throwout bearing.
SO.. what was the noise... not 100% sure... could have been the springs vibrating, might have been the clutch slipping noise, maybe it was the clutch fork rattling. Perhaps, there was a minor clearance issue and something was scraping (but, I don't know how there could not be indicating marks left). Most likely it was a combination of all these things, and showing itself as a single noise.
The turbo is fine. The VNT actuator holds a vaccum and actuates smoothly. N75 may or may not need replacing, but for the moment it's fine.
I have prematurely thought I fixed the problem in the past, so I made sure I did a lot of driving before I was sure it was gone... and it is. I never drove my car new with the Sachs DMF, so can't say if it was any good new, but it sucked by the time I got it.... so I didn't know any better and just thought DMF's sucked in general. But, this LUK DMF is so smooth and quiet. It is supposed to have more clamping force than the stock Sachs one, and supposedly is more durable. I wish I had gone this route to begin with.
Thanks to everyone who gave input and support both on this thread and the several others I have created at various stages of diagnosing this problem.
I am happy it's over, but pissed it took so long to diagnose... and now I have a $400 worthless piece of metal on my garage floor.
Happy dieseling,
John
